/PROP/TYPE16 (SH_FABR)
Block Format Keyword This property set is used to define the anisotropic layered shell property set. This property is currently only compatible with Elastic Anisotropic Fabric (/MAT/LAW58 (FABR_A)).
/PROP/TYPE16/prop_ID/unit_ID or /PROP/SH_FABR/prop_ID/unit_ID | |||||||||
prop_title | |||||||||
Ishell | Ismstr | Ish3n | P_thickfail | ||||||
hm | hf | hr | dm | ||||||
N | Istrain | Thick | Ashear | Ithick | |||||
VX | VY | VZ | Skew_ID | Ipos | |||||
ti | Zi | mat_IDi |
ti | Zi | mat_IDi |
prop_ID | Property
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
prop_title | Property
Ishell | Shell element formulation flag.
(Integer) |
Ismstr | Shell small strain
formulation flag.
(Integer) |
Ish3n | 3 node shell element
formulation flag.
(Integer) |
P_thickfail | Element suppression
criterion. It is ratio of the sum of failed integration points
thickness over total shell thickness necessary to delete the
element. 7 This option used for /FAIL/FABRIC.
(Real) |
hm | Shell membrane hourglass
coefficient. Only used when Ishell=1, 2, 3, 4. Default = 0.01 Default = 0.1 for Ishell =3 (Real) |
hf | Shell out-of-plane
hourglass. Only used when Ishell=1, 2, 3, 4. Default = 0.01 (Real) |
hr | Shell rotation hourglass
dm | Shell membrane
damping. It is used for Material LAW58. Default =0.075 for Ishell ≠12 Default =0.2 for Ishell =12 Default = 0.0 for all 3 node shells (Real) |
N | Number of layers, with
. 6
Default = 1 (Integer) |
Istrain | Compute strains for
post-processing flag.
(Integer) |
Thick | Shell
thickness. (Real) |
Ashear | Shear factor Default is Reissner value: 5/6 (Real) |
Ithick | Shell resultant stresses
calculation flag.
(Integer) |
VX | X component for reference
vector. 3 Default = 1.0 (Real) |
VY | Y component for reference
vector. Default = 0.0 (Real) |
VZ | Z component for reference
Skew_ID | Skew identifier for
reference vector. 3 If the local skew is defined, its X-axis replaces the global vector V. VX, VY, and VZ coordinates are ignored. Default = 0 (Integer) |
Ipos | Layer positioning flag for
reference vector. 4
Angle
of 1st local axis for layer
i. 3 (Real) |
Angle between first and
second axis. 3 Default = 90.0 (Real) |
ti | Thickness
ti of layer
i. (Real) |
Zi | Z position of layer i
(Zi defines the
position of the middle of the layer). Default = 0.0 (Real) |
mat_IDi | Material identifier for
layer i. Same material should be used for all
layers. (Integer) |
#RADIOSS STARTER
#- 1. LOCAL_UNIT_SYSTEM:
/UNIT/2
unit for PROP
# MUNIT LUNIT TUNIT
Mg mm s
#- 2. GEOMETRICAL SETS:
/PROP/TYPE16/2/2
prop type 16
# Ishell Ismstr Ish3n
0 0 0
# hm hf hr dm
0 0 0 0
# N Istrain Thick Ashear Ithick
3 0 1.6 0 0
# Vx Vy Vz skew_ID Ipos
1 0 1 0 0
# Phi Alpha Ti Zi mat_IDi
45 90 .5 1
90 90 .6 2
-45 90 .5 1
#enddata
- Ishell – 4-node shell
formulation flag
The hourglass formulation is visco-elastic for Q4 shells (Ishell=1,2,3,4).
- hm, hf, and hr - Hourglass coefficients
- hm, hf, and hr are used only for Q4 shells (Ishell=4). They must have a value between 0 and 0.05.
- For Ishell=3, default values of hm and hr are 0.1 with larger values possible.
- Anisotropy in local
coordinate system Two different ways to define the anisotropy with this property
- Skew_ID=0
- Anisotropic direction defined with global vector V (components defined in Line 6) and angle (angle in degree) for each layer.
- Skew_ID≠0
- Anisotropic direction defined with skew (X-axis in skew replaces the global vector ) and angle (angle in degree) for each layer.
For both ways (with vector or with skew), Projection of vector (or x-axis of skew) on shell element plane becomes the vector . Then for each layer, the anisotropic direction.
(direction 1) is vector turned degrees, where the positive direction is based on the shell normal .
Figure 1.- is the angle between local anisotropic direction 1 and 2 (directions of anisotropy) for layer i. If , then layer is in orthotropic.
- In case of reference metrics, the orientation for directions of anisotropy must be defined with the reference geometry, not the initial one.
- Ipos – Layer position
Ipos= 0: layer positions are calculated automatically.
If(1) - A warning message is displayed
- Individual layer thickness will be adjusted to new layer thickness
with:
(2) Here "Thick" and are the shell thickness and layer thickness which specified in input.
Figure 2. - Ipos = 1: all
layer positions in the element thickness are user defined (with
and
- “Thick” is not checked, as it does not need to be equal to the sum of layer thickness.
- Multiple layers are allowed to have the same space position.
For more details, refer to Layer thickness and position calculation in FAQs.
- The material law number given in /PART will be used to define the density and Young’s Modulus which then is used to calculate the time step and interface stiffness.
- Each i layer has only 1 integration point through its thickness.
- Option P_thickfail is used by /FAIL/FABRIC criterion. This is the only criterion which is compatible with /PROP/TYPE16 and /MAT/LAW58.
