/INTER/TYPE15
Block Format Keyword This interface is Ellipsoidal Surfaces to Elements Contact. It is a penalty contact interface without damping. This interface replaces interface TYPE14, especially if the mesh is coarser than the ellipsoid size.
The secondary surface must be a set of 3-node or 4-node segments (i.e. any kind of surface; except ELLIPS and MDELLIPS surfaces). The main surface must be a MADYMO hyper-ellipsoidal surface or a Radioss hyper-ellipsoidal surface, and Interface does not allow penetrations up to half the ellipsoid.
/INTER/TYPE15/inter_ID/unit_ID | |||||||||
inter_title | |||||||||
surf_IDs | surf_IDm | ||||||||
Stif | Fric |
inter_ID | Interface
unit_ID | unit_ID (Integer, maximum 10 digits) |
inter_title | Interface
surf_IDs | Secondary surface
identifier. (Integer) |
surf_IDm | Main surface
Stif | Stiffness factor. No default (Real) |
Fric | Friction coefficient. No default (Real) |
- Interface stiffness is a nonlinear increasing function of penetration. Stif is the interface stiffness when the element enters the hyper-ellipsoid (that is when penetration is zero).
