ALE Interfaces
Block Format Keyword
Several specific ALE interfaces are available in Radioss. They could be used for Fluid-structure interaction (Arbitrary Lagrangian Eulerian elements to interact with Lagrangian elements) or Fluid to fluid interaction, which is used to transmit the flow between two ALE surfaces.
ALE Interface Types
Contact Treatment   Types Application Description
ALE Tied TYPE1 Fluid structure interaction Boundary between an ALE material and a Lagrangian material.
Slide / Void TYPE9 Fluid structure interaction ALE/Lagrange, with void opening and free surface.
FLUID / FLUID TYPE12 Fluid to fluid contact Connects two fluid meshes with free, tied or periodic options.
ALE or EULER or LAG/ALE or EULER or LAG
Slide / Void TYPE18 Fluid structure interaction Coupling between a Lagrangian material and an ALE material.
Slide / Void TYPE22 Fluid structure interaction Coupling between a Lagrangian material and an ALE material.
