Create and Edit Contact Pairs
Create 2D and 3D contair pairs, and define contacts.
You can create 2D and 3D contact pairs with the Surface to Surface and Point to Surface options. You can also define contacts using the Pilot Node option.
From the Tools menu, click Surface Manager.
The Ansys Surface Manager opens and the Contact tab is displayed by default.
Click New to create a new contact pair.
The Create New Contact Pair dialog opens.
- Under Creation method, select Flexible or Pilot node.
- In the Contact type field, select 2D or 3D.
- Under Create from, select whether to create a surface to surface contact pair or a point to surface contact pair.
Under Symmetric Contact, select Yes or
No.
To create two pairs of symmetry contacts, click Yes. In order to create a symmetry pair, the selected elements must meet all of the element configuration requirements.
- Contact elements in the first pair will be target elements in the second pair.
- Target elements in first pair will be contact elements in the second pair.
- Different properties and ET types will be created for the second pair. You can update the contact pair with desired properties and contact options later.
- Click Pick Target to select the target body components.
- From the panel area, click the comps selector.
- Select the components that belong to the target component elements.
- Click select.
- Click proceed.
- In the Target Elements Selection dialog, click the Elements selector.
- In the パネル領域, verify that the elems selector is active, then select the target elements of the contact pair.
- Click proceed.
Next.
The Target Component Details dialog opens.注: This dialog displays a default name and color for the target component, which can both be modified. You can also modify the ET Type name and the ID of the target component, as well as the values of the key options. Once Save Keyopts is clicked, all of your changes will be applied to the target element. The next time you create a new contact pair, the options you selected in the dialog will be saved and you will not need to apply them again.
図 1. - Click Next.
- In the Contact Components Selection dialog, click the Components selector.
- In the パネル領域, click the comps selector.
- Select the components to assign as the target body.
- Click select.
- Click proceed.
- Click Next.
- In the Select Contact Elements dialog, click the Elements selector.
- In the パネル領域, verify that the elems selector is active, then select the elements to assign as the contact surface elements.
- Click proceed.
Click Next.
The Contact Component Details dialog opens.注: This dialog displays a default name and color for the contact component, which can be modified if desired. The ET type and the ID of the contact component can also be modified.
- Click Next.
In the Contact Property dialog, enter the values for items
shown. You can create a new property, or create a new one based on an existing
property, which helps expedite the process. Click Save real
constants to save the property values you entered. In the
future, when the Contact Property dialog opens, the values
you saved will appear by default.
図 2. - Click Next.
In the Contact Material dialog, click
New to define a new material or select
None to skip defining a material.
図 3. -
Click Next.
The Ansys Surface Manager dialog opens and displays a summary of the target and contact elements. The contact pair you created is displayed.
- To exit the Ansys Surface Manager, click Close.
- To repeat this process, click Restart.
