Auto Contact Browser
The Auto Contact Browser provides options for viewing and modifying the contact pairs identified in the auto contact process.
Column | Description |
Name | Lists the name of the interfaces, surfaces and surface
interactions that were assigned. Underneath the interface name are the temporary surfaces included in that interface. Red indicates a secondary surface, and blue indicates a main surface. |
Accept | When the Accept box is checked, the Interface will be included in the creation process. |
Color | Color assigned to the interaction and surfaces |
ET Type | ET Type |
Real Set | |
Mat | Material assigned |
Icon | Description |
Options | Opens the Options dialog. Enter a new feature angle or customize the transparency for a selected entity. Click OK when finished. |
Highlight Elements | Highlights the elements stored in selected entities in the graphics window. You can use the Control and Shift key to select multiple items in the table. |
Review Elements | Review of elements stored in the selected entities. Elements
are highlighted by color; all other components are grayed out.
table. Review and Highlight are mutually exclusive. It is also possible to switch both options off. This is helpful when working with big models. |
Fit View to Elements | Automatically zooms in to the elements stored in the currently selected items. |
Display All Elements | In combination with the Highlight Elements or the Review Elements option, current contents remain unchanged on the screen. |
Display Components with Elements | Highlights or reviews the elements referred by an interaction or surfaces and shows the components they belong to. All other components will be masked. |
Display Only Elements | Only elements are highlighted or reviewed. The rest of the component and other components will be masked. |
Select Elements Manually | Opens the Element selection panel so that individual elements can be added/removed manually. Click proceed when finished. |
Add by Adjacent | Adds the elements adjacent to the surface to the selected
surface. Right-click to undo one time. |
Add by Face | Adds the adjacent face to the selected surface. Right-click to undo one time. |
Recheck | Opens the Auto Contact dialog to recheck
the select interfaces. Recheck will either add more contacts to
the existing contacts for modify the existing ones. You can select interfaces from the browser, and the GUI will automatically populate the components that the interaction was based on. This helps modify an existing interface. |
