/MAT/LAW33 (FOAM_PLAS)
Block Format Keyword This law models a viscous-elastic foam material with unloading/reloading like plastic behavior. This law is applicable only for solid elements and is typically used to model low density, closed cell polyurethane foams such as impact limiters.
/MAT/LAW33/mat_ID/unit_ID or /MAT/FOAM_PLAS/mat_ID/unit_ID
mat_title
ρ i
E Ka fct_IDf Fscalecrv
P0 Φ γ 0
A B C
Read only if Ka = 1
E1 E2 Et η * η 0
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young's modulus.
(Real)
[ Pa ]
Ka Analysis type flag.
= 0
The skeletal behavior before yield is elastic.
= 1
The skeletal behavior before yield is visco-elastic.
(Integer)
fct_IDf Yield stress vs. volumetric strain curve function identifier.
(Integer)
Fscalecrv Scale factor for ordinate (stress) for fct_IDf.
Default = 1.0 (Real)
[ Pa ]
P0 Initial air pressure. 5
(Real)
[ Pa ]
Φ Ratio of foam to polymer density.
(Real)
γ 0 Initial volumetric strain.
(Real)
A Yield parameter.
(Real)
B Yield parameter.
(Real)
C Yield parameter.
(Real)
E1 Coefficient for Young's modulus update.
(Real)
[ Pas ]
E2 Coefficient for Young's modulus update.
(Real)
[ Pa ]
Et Tangent modulus.
(Real)
[ Pa ]
η * Viscosity coefficient in pure compression.
(Real)
η 0 Viscosity coefficient in pure shear.
(Real)
Example (Foam)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/FOAM_PLAS/1/1
Foam
#              RHO_I
               2E-10
#                  E        Ka  func_IDf          Fscalecurv
                 200         1         0                   1
#                 P0                 Phi             Gamma_0
                   0                   0                   0
#                  A                   B                   C
                1E30                   0                   0
#                 E1                  E2                  Et            eta_comp           eta_shear
                   0                   0                   2                2E27                1E27
#ENDDATA
/END
  1. If the limiting yield curve is not defined, then the material follows a Maxwell-Kelvin-Voight visco-elastic model.
    clip0061
  2. If the limiting yield curve is defined, then the material initially follows the visco-elastic law until it intersects the defined yield curve, which limits the visco-elastic stress in tension and compression. The material does not experience plasticity, but instead behaves in a visco hyperelastic way.
  3. If the yield function fct_IDf = 0, then(1)
    σ y = A + B ( 1 + C γ )
    Where, γ is the volumetric strain:(2)
    γ = V V 0 1 + γ 0 = ρ 0 ρ 1 + γ 0 = μ 1 + μ + γ 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHZoWzcq GH9aqpdaWcaaqaaiaadAfaaeaacaWGwbWaaSbaaSqaaiaaicdaaeqa aaaakiabgkHiTiaaigdacqGHRaWkcqaHZoWzdaWgaaWcbaGaaGimaa qabaGccqGH9aqpdaWcaaqaaiabeg8aYnaaBaaaleaacaaIWaaabeaa aOqaaiabeg8aYbaacqGHsislcaaIXaGaey4kaSIaeq4SdC2aaSbaaS qaaiaaicdaaeqaaOGaeyypa0ZaaSaaaeaacqGHsislcqaH8oqBaeaa caaIXaGaey4kaSIaeqiVd0gaaiabgUcaRiabeo7aNnaaBaaaleaaca aIWaaabeaaaaa@5604@
  4. If the yield function fct_IDf ≠ 0, then σ vs. γ is read from input of the curve idenfier fct_IDf. The curve can be defined for tensile ( γ > 0 ) and compression ( 1 < γ < 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaeyOeI0IaaGymaiabgYda8iabeo7aNjabgYda8iaaicdaaaa@3C1D@ ). The input stress should be positive for both tension and compression.
    mat_law33_curve
  5. The optional air pressure, as a function of the volumetric strain can be added to the structural pressure. Pressure is applied only on the spherical part of the stress tensor.(3)
    P a i r = P 0 γ 1 + γ Φ
  6. Young’s modulus is used as the initial slope for unloading. It can be constant or variable, based on the strain rate.(4)
    E = max ( E , E 1 ε ˙ + E 2 )
  7. The unloading or the loading direction change (tensile <-> compression) is following the current elastic modulus, like an isotropic elastic-plastic material or highly viscous foam material. However, there is no plastic strain accumulation.
    Figure 3.
