/MAT/LAW90
Block Format Keyword This law describes the visco-elastic foam tabulated material. This material law can be used only with solid elements.
/MAT/LAW90/mat_ID/unit_ID
mat_title
ρ i
E0 ν MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AE@
NL Ismooth Fcut Shape Hys
If NL0, each loading function per line
fct_IDL ε ˙ L FscaleL
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρ i Initial density
(Real)
[ kg m 3 ]
E0 Initial Young's modulus. 2
(Real)
[ Pa ]
ν MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AE@ Poisson's ratio.
(Real)
Ismooth Smooth strain rate option flag.
= 0 (Default)
No strain rate smoothing.
= 1
Strain rate smoothing active.
(Integer)
Fcut Cutoff frequency for strain rate filtering.
Default = 1030 (Real)
[Hz]
NL Number of loading functions.
(Integer)
fct_IDL Load function (in compression) identifier.
(Integer)
ε ˙ L Strain rate for load function.
(Real)
[ 1 s ]
FscaleL Load function scale factor.
(Real)
[ Pa ]
Shape Shape factor.
Default = 1.0 (Real)
Hys Hysteresis unloading factor.
#RADIOSS STARTER
/UNIT/1
unit for mat
                  kg                  mm                  ms
#-  2. MATERIALS:
/MAT/LAW90/1/1
foam
#              RHO_I
                3E-8
#                 EO                  NU
                0.01                   0
#    Nload   Ismooth               F_cut               Shape                 Hys
         3         1                  10                 10.                0.15
#  fct_IDL          Eps_._load          Fscaleload
        12                  .1                   0
        13                   1                   0
        13                 100                   0
#-  3. FUNCTIONS:
/FUNCT/12
NULL
#                  X                   Y
              -0.300              -0.546
              -0.200              -0.534
              -0.100              -0.398
               0.000               0.000
               0.010               0.065
               0.020               0.105
               0.030               0.123
               0.040               0.129
               0.050               0.134
               0.060               0.138
               0.070               0.142
               0.080               0.145
               0.090               0.150
               0.100               0.153
               0.200               0.183
               0.300               0.211
               0.400               0.243
               0.500               0.287
               0.600               0.356
               0.700               0.489
               0.800               0.828
               0.900               2.434
               0.950              11.978
               0.960              24.042
               0.970              74.879
               0.980             460.893
               0.99             12810.97
/FUNCT/13
NULL
#                  X                   Y
              -0.300              -0.546
              -0.200              -0.534
              -0.100              -0.398
               0.000               0.000
               0.010               0.065
               0.020               0.105
               0.030               0.123
               0.040               0.129
               0.050               0.134
               0.060               0.138
               0.070               0.142
               0.080               0.145
               0.090               0.150
               0.100               0.153
               0.200               0.183
               0.300               0.211
               0.400               0.243
               0.500               0.287
               0.600               0.356
               0.700               0.489
               0.800               0.828
               0.900               2.434
               0.950              11.978
               0.960              24.042
               0.970              74.879
               0.980             460.893
               0.99             12810.97
#ENDDATA
/END
  1. Control of the unloading response: There are two ways for controlling the unloading:
    • If Hys=0, follow the quasi-static loading curve for unloading.
    • If Hys > 0, the loading curve are used for both loading and unloading behavior and the tensor unloading tensor stress is reduced by:(1)
      σ = ( 1 D ) σ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHdpGaey ypa0ZaaeWaaeaacaaIXaGaeyOeI0IaamiraaGaayjkaiaawMcaaiaa ho8aaaa@3DFC@
      With(2)
      D = ( 1 H y s ) ( 1 ( W c u r W max ) S h a p e ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGebGaey ypa0ZaaeWaaeaacaaIXaGaeyOeI0IaamisaiaadMhacaWGZbaacaGL OaGaayzkaaWaaeWaaeaacaaIXaGaeyOeI0YaaeWaaeaadaWcaaqaai aadEfadaWgaaWcbaGaam4yaiaadwhacaWGYbaabeaaaOqaaiaadEfa daWgaaWcbaGaciyBaiaacggacaGG4baabeaaaaaakiaawIcacaGLPa aadaahaaWcbeqaaiaadofacaWGObGaamyyaiaadchacaWGLbaaaaGc caGLOaGaayzkaaaaaa@4F7D@
      Where, W c u r MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbWaaS baaSqaaiaadogacaWG1bGaamOCaaqabaaaaa@3A3F@ and W max MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbWaaS baaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3A3A@ are current and maximum quasi-static energy.
  2. For stresses above the last load function, the behavior is extrapolated by using the two last load functions. Then, in order to avoid huge stress values, it is recommended to repeat the last load function.
  3. The loading curve should be defined as:
    • Positive abscissa and ordinate for the compression
    • Negative abscissa and ordinate for traction (tension)
  4. In order to recover the stress and strain using initial state file, the following options have to be saved in ASCII Output File (STY-File):
    • /OUTP/STRESS/FULL
    • /OUTP/STRAIN/FULL
    • /OUTP/USERS/FULL
  5. Specific material output variables:
    • USR2: Maximum for quasi-static energy W max MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbWaaS baaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3A3A@
    • USR3: Strain rate in principal direction 1
    • USR4: Strain rate in principal direction 2
    • USR5: Strain rate in principal direction 3
  6. /VISC/PRONY can be used with this material law to include viscous effects.
