/MAT/LAW40 (KELVINMAX)
Block Format Keyword This law describes the generalized Maxwell-Kelvin material. This law can only be used with solid elements.
/MAT/LAW40/mat_ID/unit_ID or /MAT/KELVINMAX/mat_ID/unit_ID
mat_title
ρ i
K G Astass Bstass Kvm
G1 G2 G3 G4 G5
β 1 β 2 β 3 β 4 β 5
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρ i Initial density
(Real)
[ kg m 3 ]
K Bulk modulus
(Real)
[ Pa ]
G Long time shear modulus
(Real)
[ Pa ]
Astass Stassi A coefficient
(Real)
[ Pa ]
Bstass Stassi B coefficient
(Real)
[ Pa ]
Kvm von Mises coefficient
(Real)
G1 Shear modulus 1
(Real)
[ Pa ]
G2 Shear modulus 2
(Real)
[ Pa ]
G3 Shear modulus 3
(Real)
[ Pa ]
G4 Shear modulus 4
(Real)
[ Pa ]
G5 Shear modulus 5
(Real)
[ Pa ]
β 1 Time decay constant 1
(Real)
β 2 Time decay constant 2
(Real)
β 3 Time decay constant 3
(Real)
β 4 Time decay constant 4
(Real)
β 5 Time decay constant 5
(Real)
Example (Elastic Rubber)
#RADIOSS STARTER
/UNIT/1
unit for mat
                 Mg                  mm                   s
#-  2. MATERIALS:
/MAT/KELVINMAX/1/1
LAW40 elastic rubber
#              RHO_I
                1E-9
#                  K               G_inf              Astass              Bstass                 Kvm
                8.97                   3                   0                   0                   0
#                 G1                  G2                  G3                  G4                  G5
                   0                   0                   0                   0                   0
#              BETA1               BETA2               BETA3               BETA4               BETA5
                   0                   0                   0                   0                   0
#ENDDATA
/END
  1. Shear modulus is computed using the following equation:(1)
    G ( t ) = G + 1 5 G i e β i t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGhbWaae WaaeaacaWG0baacaGLOaGaayzkaaGaeyypa0Jaci4ramaaBaaaleaa cqGHEisPaeqaaOGaey4kaSYaaabCaeaacaWGhbWaaSbaaSqaaiaadM gaaeqaaOGaamyzamaaCaaaleqabaGaeyOeI0IaeqOSdi2aaSbaaWqa aiaadMgaaeqaaSGaamiDaaaaaeaacaaIXaaabaGaaGynaaqdcqGHri s5aaaa@496E@
    with β i = 1 τ i
    Where τ i is the relaxation time.
  2. Variables Kvm, Astass, and Bstass are not used in this material law; except for some output in user variables.
  3. Poisson number "NU" ( ν ) is calculated automatically with bulk modulus K and initial shear modulus G at time= 0, as:(2)
    ν = 3 K 2 G 2 ( 3 K + G )
    Where, initial shear modulus G = G + G 1 + G 2 + G 3 + G 4 + G 5
    Poisson number "NU" ( ν ) must be positive and 0 < ν < 0.5 .
