Nonlinear finite element analyses confront users with many choices. An understanding of the fundamental concepts of
nonlinear finite element analysis is necessary if you do not want to use the finite element program as a black box.
The purpose of this manual is to describe the numerical methods included in Radioss.
Kinematic constraints are boundary conditions that are placed on nodal velocities. They are mutually exclusive for each degree
of freedom (DOF), and there can only be one constraint per DOF.
The stability of solution concerns the evolution of a process subjected to small perturbations. A process is considered
to be stable if small perturbations of initial data result in small changes in the solution. The theory of stability
can be applied to a variety of computational problems.
A large variety of materials is used in the structural components and must be modeled in stress analysis problems.
For any kind of these materials a range of constitutive laws is available to describe by a mathematical approach the
behavior of the material.
This material law can be used to model low density closed cell polyurethane foams, impactors, impact limiters. It can
only be used with solid elements.
Explicit scheme is generally used for time integration in Radioss, in which velocities and displacements are obtained by direct integration of nodal accelerations.
The performance criterion in the computation was always an essential point in the architectural conception of Radioss. At first, the program has been largely optimized for the vectored super-calculators like CRAY. Then, a first parallel
version SMP made possible the exploration of shared memory on processors.
impactors, impact limiters. It can only be used with solid elements.
The main assumptions in this law are:
The components of the stress tensor are uncoupled until full volumetric compaction is
achieved (Poisson's ratio = 0.0).
The material is isotropic.
The effect of the enclosed air is considered via a separate Pressure vs Volumetric
Strain relation:
(1)
with:(2)
Where,
Volumetric strain
Porosity
Initial air pressure
Initial volumetric strain
The structural stresses follow the Maxwell-Kelvin-Voight viscoelastic model (Generalized Kelvin-Voigt Model (LAW35), Equation 12 before the limiting yield curve is
reached): Figure 1. Maxwell-Kelvin-Voight Model
(3)
The Young's modulus used in the calculation is:
Yield is defined by a user-defined curve vs volumetric strain,
, or
Yield is applied to the principal structural stresses.
Unloading follows Young's modulus, which results in viscous unloading.
The full stress tensor is obtained by adding air pressure to the structual stresses:
