Appendix A: Conversion Tables and Constants
| US & UK >> Metric System | Metric System >> US & UK | ||
| 1 Inch (in) - US | 25.40005 mm | 1 millimeter (mm) | 0.03937 in (US) |
| 1 Inch (in) - UK | 25.39996 mm | 1 millimeter (mm) | 0.03937 in (UK) |
| 1 Foot (ft) = (12.in) - US | 0.3048006 m | 1 meter (m) | 3.28083 ft (US) |
| 1 Foot (ft) = (12.in) - UK | 0.3047995 m | 1 meter (m) | 3.28083 ft (UK) |
| 1 Yard (yd) = (3.ft) - US | 0.9144018 m | 1 meter (m) | 1.093611 yd (US) |
| 1 Yard (yd) = (3.ft) - UK | 0.9143984 m | 1 meter (m) | 1.093611 yd (UK) |
| 1 Mile (mi) = (1760.yd) - US | 1.609347 km | 1 kilometer (km) | 1 kilometer (km) |
| 1 Mile (mi) = (1760.yd) - UK | 1.609341 km | 1.609341 km | 0.6213724 mi (UK) |
| 1 Nautical mile (UK) | 1.853181 km | 1 kilometer (km) | 0.5396127 n.mi (UK) |
| 1 hectare (ha) | 2.471044 acre (US) | ||
| 1 Acre - US | 0.4046873 ha | 1 hectare (ha) | 2.471044 acre (US) |
| 1 Acre - UK | 0.4046842 ha | 1 hectare (ha) | 2.4711 acre (UK) |
| 1 Square inch (sq in) - US | 6.451626 cm2 | 1 Square centimeter (cm2) | 0.1549997 sq. in (US) |
| 1 Square inch (sq in) - UK | 6.451578 cm2 | 1 Square centimeter (cm2) | 0.1550 sq.in (UK) |
| 1 Square foot (sq ft) = 144 sq in - US | 0.09290341 m2 | 1 Square meter (m2) | 10.76387 sq.ft (US) |
| 1 Square foot (sq ft) = 144 sq in - UK | 0.09290272 m2 | 1 Square meter (m2) | 10.7639 sq.ft (UK) |
| 1 Square yard (sq yd) = 9 sq.ft - US | 0.8361307 m2 | 1 Square meter (m2) | 1.195985 sq.yd (US) |
| 1 Square yard (sq yd) = 9 sq.ft - UK | 0.8361245 m2 | 1 Square meter (m2) | 1.1960 sq.yd (UK) |
| 1 Square mile (sq mi) = 640 acres - US | 2.589998 km2 | 1 Square kilometer (km2) | 0.3861006 sq.mi (US) |
| 1 Square mile (sq mi) = 640 acres - UK | 2.589979 km2 | 1 Square kilometer (km2) | 0.3861 sq.mi (UK) |
| 1 Cubic inch (cu in) - US | 16.3871 cm3 | 1 Cubic centimeter (cm3) | 0.06102509 cu in (US) |
| 1 Cubic inch (cu in) - UK | 16.38698 cm3 | 1 Cubic centimeter (cm3) | 0.0610241 cu in (UK) |
| 1 Cubic foot (cu ft) - US | 28.31702 dm3 | 1 Cubic decimeter (dm3) | 0.03531544 cu ft (US) |
| 1 Cubic foot (cu ft - (UK) | 28.31670 dm3 | 1 Cubic decimeter (dm3) | 0.0353148 cu ft (UK) |
| 1 Cubic yard (cu yd) - US | 0.7645594 m3 | 1 Cubic meter (m3) | 1.307943 cu yd (US) |
| 1 Cubic yard (cu yd) - UK | 0.7645509 m3 | 1 Cubic meter (m3) | 1.307957 cu yd (UK) |
| 1 fluid ounce (fl oz) - US | 29.5735 cm3 (or ml) | 1 Cubic decimeter (dm3) | 33.814 fl oz |
| 1 fluid ounce (fl oz) - UK | 28.4131 cm3 (or ml) | 1 Cubic decimeter (dm3) | 35.195 fl oz |
| 1 Bushel (US) | 35.23829 dm3 (or liter) | 1 Cubic decimeter (dm3) | 0.0283782 bu (US) |
| 1 Bushel (UK) | 36.36770 dm3 (or liter) | 1 Cubic decimeter (dm3) | 0.02749692 bu (UK) |
| 1 Gallon (US) | 3.785329 dm3 (or liter) | 1 Cubic decimeter (dm3) | 0.2641779 gal (US) |
| 1 Gallon (UK) | 4.545963 dm3 (or liter) | 1 Cubic decimeter (dm3) | 0.2199754 gal (UK) |
| 1 Liquid pint (US) | 0.4731661 dm3 (or liter) | 1 Cubic decimeter (dm3) | 2.113423 liq.pt (US) |
| 1 Pint(pt) = 20 fl oz - UK | 0.5682454 dm3 (or liter) | 1 Cubic decimeter (dm3) | 1.759803 pt (UK) |
| 1Grain (gr) - US | 64.79892 mg | 1 milligram (mg) | 0.01543236 gr (US) |
| 1Grain (gr) - UK | 64.79892 mg | 1 milligram (mg) | 0.01543236 gr (UK) |
| 1Ounce (oz) - US | 28.34953 g | 1 gram (g) | 0.03527396 oz av. (US) |
| 1Ounce (oz) - UK | 28.34953 g | 1 gram (g) | 0.03527396 oz av. (UK) |
| 1Pound (lb) = 16 oz - US | 0.4535924 kg | 1 kilogram (kg) | 2.204622 lb av. (US) |
| 1Short hundredweight(sh cwt)= 100 Ib - US | 45.35924 kg | 1kilogram (kg) | 0.02204622 sh.cwt (US) |
| 1Cental (UK) | 45.35924 kg | 1 kilogram (kg) | 0.02204622 ctl (UK) |
| 1Long ton (l tn) = 2240 Ib - US | 1.016047 t | 1 ton | 0.9842064 l.tn (US) |
| 1Ton (UK) | 1.016047 t | 1 ton | 0.9842064 tn (UK) |
- Attention should be paid to not confuse mass and weight.
- The mass (kg) is an intrinsic characteristic of the body and is measured in kilogram.
- The weight is a force which depends on terrestrial attraction and it is the equivalent of the mass of a body by the acceleration of gravity (9.80665 at the sea level) and is measured in Newton [ N ].
- The specific mass is the quotient of the mass of a body by its volume.
- The unit of mass of S.I. = kilogram.
| Symbol | SI Equivalent | Designation of Unit Measure |
| 1 Bz | = 1 m/s | benz |
| 1 cm/min | = 1.66667 x 10-4 m/s | centimeter per minute |
| 1 cm/s | = 0.01 m/s | centimeter per second |
| 1 ft/h, fph | = 8.46667 x 10-5 m/s | foot per hour |
| 1 ft/min, fpm | = 0.00508 m/s | foot per minute |
| 1 ft/s, fps | = 0.3048 m/s | foot per second |
| 1 furlong/fortnight | = 1.66309 x 10-4 m/s | furlong per fortnight |
| 1 in/s, ips | = 0.0254 m/s | inch per second |
| 1 km/h | = 0.277778 m/s | kilometer per hour |
| 1 kn, knot | = 0.514444 m/s | knot (node) |
| 1 cm/s | = 0.01 m/s | kyne |
| 1 m/min | = 166.667 m/s | meter per minute |
| 1 m/s | = 1 m/s | meter per second |
| 1 mpy | = 8.04327 x 10-13 m/s | mil per year |
| 1 knot | = 0.514444 m/s | mile (naut.) per hour (knot. node) |
| 1 mph, mi/h | = 0.44704 m/s | mile (stat.) per hour |
| mi/min | = 26.8224 m/s | mile (stat.) per minute |
| 1 mm/min | = 1.66667 x 10-5 m/s | millimeter per minute |
| 1 mm/s | = 0.001 m/s | millimeter per second |
| Conversion Type | Conversion Formula |
| Degrees Celsius (C) to degrees Kelvin (K) | = (C) + 273.15 = (K) |
| Degrees Celsius (C) to degrees Fahrenheit (F) | = [(C) * 1.8] + 32 = (F) |
| Degrees Celsius (C) to degrees Rankine (R) | = [(C) * 1.8] + 491.67 = (R) |
| Degrees Fahrenheit (F) to degrees Kelvin (K) | = [(F) * 0.555556] + 255.37 = (K) |
| Degrees Fahrenheit (F) to degrees Rankine (R) | = (F) + 459.67 = (R) |
| Degrees Kelvin (K) to degrees Rankine (R) | = (K) * 1.8 = (R) |
| Degrees Rankine (R) to degrees Celsius (C) | = [(R) - 491.67] * 0.555556 = (C) |
| Degrees Rankine (R) to degrees Kelvin (K) | = (R) * 0.555556 = (K) |
| 1 at | = 98066.5 Pa | atmosphere (metric) |
| 1 atm | = 101325 Pa | atmosphere (standard) |
| 1 bar | = 100000 Pa | bar |
| 1 cmHg (0° C) | = 1333.22 Pa | centimeter of mercury (0° C) |
| 1 cmH2O | = 98.0638 Pa | centimeter of water (4° C) |
| 1 dyn/cm2 | = 0.1 Pa | dyne per square centimeter |
| 1 ft H2O | = 2988.98 Pa | foot of water (4° C) |
| 1 hPa | = 100 Pa | hectopascal |
| 1 inHg (0° C) | = 3386.38 Pa | inch of mercury (0° C) |
| 1 inHg (15.56° C) | = 3377.18 Pa | inch of mercury (15.56° C) |
| 1 inH2O (15.56° C) | = 248.845 Pa | inch of water (15.56° C) |
| 1 inH2O (4° C) | = 249.082 Pa | inch of water (4° C) |
| 1 kgf/cm2 | = 98066.5 Pa | kilogram force per square centimeter |
| 1 kgf/dm2 | = 980.665 Pa | kilogram force per square decimeter |
| 1 kgf/m2 | = 9.80665 Pa | kilogram force per square meter |
| 1 kgf/mm2 | = 9806650 Pa | kilogram force per square millimeter |
| 1 kPa | = 1000 Pa | kilopascal |
| 1 kip/in2, ksi, KSI | = 6894760 Pa | kilopound force per square inch |
| 1 MPa | = 1000000 Pa | megapascal |
| 1 mH2O, mCE (15.56° C) | = 9797.06 Pa | meter of water (15.56° C) |
| 1 mH2O, mCE (4° C) | = 9806.38 Pa | meter of water (4° C) |
| 1 bar | = 0.1 Pa | microbar (barye, barrie) |
| 1 Hg (0° C) | = 0.133322 Pa | micron of mercury (millitorr) |
| 1 mbar | = 100 Pa | millibar |
| 1 mmHg, torr, Torr (0 °C) | = 133.322 Pa | millimeter of mercury (0° C) |
| 1 mmH2O, mmCE (15.56° C) | = 9.79706 Pa | millimeter of water (15.56° C) |
| 1 mmH2O, mmCE (4° C) | = 9.80638 Pa | millimeter of water (4° C) |
| 1 N/m2 | = 1 Pa | newton per square meter |
| 1 Pa, N/m2 | = 1 Pa | pascal |
| 1 lbf/ft2 | = 47.8803 Pa | pound force per square foot |
| 1 psi, PSI, lbf/in2 | = 6894.76 Pa | pound force per square inch |
| 1 atm | = 101325 Pa | standard atmosphere |
| 1 tonf/cm2 (metric) | = 98066500 Pa | ton force (metric) per square centimeter |
| 1 tonf/m2 (metric) | = 9806.65 Pa | ton force (metric) per square meter |
| 1 torr | = 133.322 Pa | torr |
| 1 acre-ft/month | = 4.69361 x 10-4 m3/s | acre foot per month |
| 1 bbl (US, liq.)/day | = 1.3801 x 10-6 m3/s | barrel (US, liq.) per day |
| 1 bbl (US, petrol)/day | = 1.84013 x 10-6 m3/s | barrel (US, petrol) per day |
| 1 cm3/s | = 1 x 10-6 m3/s | cubic centimeter per second |
| 1 CFM, cfm, ft3/min | = 4.71947 x 10-4 m3/s | cubic foot per minute |
| 1 cfs, ft3/s | = 0.0283168 m3/s | cubic foot per second |
| 1 in3/min | = 2.73118 x 10-7 m3/s | cubic inch per minute |
| 1 in3/s | = 1.63871 x 10-5 m3/s | cubic inch per second |
| 1 m3/h | = 2.77778 x 10-4 m3/s | cubic meter per hour |
| 1 m3/min | = 0.0166667 m3/s | cubic meter per minute |
| 1 m3/s | = 1 m3/s | cubic meter per second |
| 1 yd3/min | = 0.0127426 m3/s | cubic yard per minute |
| 1 cumec | = 1 m3/s | cumec (musec) |
| 1 gal (UK)/day | = 5.26168 x 10-8 m3/s | gallon (UK) per day |
| 1 gph (UK) | = 1.2628 x 10-6 m3/s | gallon (UK) per hour |
| 1 gpm (UK) | = 7.57682 x 10-5 m3/s | gallon (UK) per minute |
| 1 gps (UK) | = 4.54609 x 10-3 m3/s | gallon (UK) per second |
| 1 gal (US, liq.)/day | = 4.38126 x 10-8 m3/s | gallon (US, liq.) per day |
| 1 gph (US) | = 1.0515 x 10-6 m3/s | gallon (US, liq.) per hour |
| 1 gpm (US) | = 6.30902 x 10-5 m3/s | gallon (US, liq.) per minute |
| 1 gps (US) | = 0.00378541 m3/s | gallon (US, liq.) per second |
| 1 l/h | = 2.77778 x 10-7 m3/s | liter per hour |
| 1 l/min | = 1.66667 x 10-5 m3/s | liter per minute |
| 1 l/s | = 0.001 m3/s | liter per second |
| Density (kg/m^3) |
Elastic Modulus (Pa) |
Poisson's Ratio | Thermal Expansion Coefficient (Microns/m C) |
Heat Capacity J/kg(°C) |
| Aluminum 2024-T3 | 2770 | 7.310E+10 | 0.3300 | 22.68 | 963.00 |
| Aluminum 6061-T6 | 2700 | 7.310E+10 | 0.3300 | 24.30 | 963.00 |
| Aluminum 7079-T6 | 2740 | 7.172E+10 | 0.3300 | 24.66 | 963.00 |
| Concrete | 2242 | 1000 | |||
| Copper - pure | 8900 | 1.172E+11 | 16.56 | 385.00 | |
| Gold - pure | 19320 | 7.448E+10 | 0.4200 | 4.39 | 130.00 |
| Iron | 7830 | 440.00 | |||
| Lead - pure | 11340 | 1.379E+10 | 0.4200 | 52.74 | 130.00 |
| Magnesium AZ31B-H24 | 1770 | 4.483E+10 | 0.3500 | 26.10 | 1047 |
| Magnesium HK31A-H24 | 1790 | 4.414E+10 | 0.3500 | 25.20 | 544.00 |
| Nickel - pure | 8900 | 2.207E+11 | 12.96 | 461.00 | |
| Platinum | 21450 | 1.469E+11 | 0.3900 | 9.0000 | 130.00 |
| Silver - pure | 10500 | 7.241E+10 | 0.3700 | 19.80 | 235.00 |
| Steel AISI 304 | 8030 | 1.931E+11 | 0.2900 | 17.82 | 503.00 |
| Steel AISI C1020 | 7850 | 2.034E+11 | 0.2900 | 11.34 | 419.00 |
| Tantalum | 16600 | 1.862E+11 | 0.3500 | 6.4800 | 126.00 |
| Titanium B 120VCA | 4850 | 1.021E+11 | 0.3000 | 9.3600 | 544.00 |
| Tungsten | 19300 | 3.448E+11 | 0.2800 | 4.5000 | 138.00 |
| Molar Weight | Heat Capacity | |||||||
| Gas | MW [kg/mol] | a [J/(mol K)] | b [J/(mol K2)] | c [J/(mol K3)] | d [J/(mol K4)] | e [J K/mol] | Temp.range [K] | |
| Nitrogen | N2 | 0,02801 | 26,092000 | 8,2188E-03 | -1,9761E-06 | 1,5927E-10 | 4,4434E+04 | 298-6000 |
| Oxygen | O2 | 0,032 | 29,659000 | 6,1373E-03 | -1,1865E-06 | 9,5780E-11 | -2,1966E+05 | 298-6000 |
| Carbon dioxide | CO2 | 0,04401 | 24,997350 | 5,5187E-02 | -3,3691E-05 | 7,9484E-09 | -1,3664E+05 | 298-1200 |
| Carbon monoxide | CO | 0,02801 | 25,567590 | 6,0961E-03 | 4,0547E-06 | -2,6713E-09 | 1,3102E+05 | 298-1300 |
| Argon | Ar | 0,03995 | 20,786000 | 2,8259E-10 | -1,4642E-13 | 1,0921E-17 | -3,6614E-02 | 298-6000 |
| Neon | Ne | 0,02018 | 20,786030 | 4,8506E-13 | -1,5829E-16 | 1,5251E-20 | 3,1963E-05 | 298-6000 |
| Helium | He | 0,004 | 20,786030 | 4,8506E-13 | -1,5929E-16 | 1,5251E-20 | 3,1963E-05 | 298-6000 |
| Hydrogen | H2 | 0,00202 | 33,066178 | -1,1363E-02 | 1,1433E-05 | -2,7729E-09 | -1,5856E+05 | 298-1000 |
| Water vapour | H2O | 0,01802 | 30,092000 | 6,8325E-03 | 6,7934E-06 | -2,5345E-09 | 8,2139E+04 | 500-1700 |
| Ammonia | NH3 | 0,01703 | 19,995630 | 4,9771E-02 | -1,5376E-05 | 1,9212E-09 | 1,8917E+05 | 298-1400 |
| Hydrogen sulphide | H2S | 0,03408 | 26,884120 | 1,8678E-02 | 3,4342E-06 | -3,3787E-09 | 1,3588E+05 | 298-1400 |
| Benzene | C6H6 | 0,07811 | -36,220000 | 4,8475E-01 | -3,1570E-04 | 7,7620E-08 | 0,0000E+00 | 298-1500 |
| Nitrous oxide | N2O | 0,04401 | 27,679880 | 5,1149E-02 | -3,0645E-05 | 6,8479E-09 | -1,5791E+05 | 298-1400 |
| Length | Time | Mass | Force | Pressure | Velocity | Energy | G | |
| m | s | Kg | Kg m/s2 | N/m2 | m/s | Kg/m3 | Kmg2/s2 | 9.81 |
| m | s | Kg | N | Pa | m/s | m Kg/l | J | 9.81 |
| m | s | g | mN | mPa | m/s | Kg/l | mJ | 9.81 |
| m | s | Mg(ton | KN | KPa | m/s | Kg/l | KJ | 9.81 |
| m | ms | Kg | MN | MPa | Km/s | m Kg/l | MJ | 9.81e-6 |
| m | ms | g | KN | KPa | Km/s | Kg/l | KJ | 9.81e-6 |
| m | ms | Mg(ton) | GN | GPa | K/ms | Kg/l | GJ | 9.81e-6 |
| mm | s | Kg | mN | KPa | mm/s | M Kg/l | J | 9.81e+3 |
| mm | s | g | N | Pa | mm/s | K Kg/l | nJ | 9.81e+3 |
| mm | s | Mg(ton) | N | MPa | mm/s | G Kg/l | mJ | 9.81e+3 |
| mm | ms | Kg | KN | GPa | m/s | M Kg/l | J | 9.81e-3 |
| mm | ms | g | N | MPa | m/s | K Kg/l | mJ | 9.81e-3 |
| mm | ms | Mg(ton) | MN | TPa | m/s | G Kg/l | KJ | 9.81e-3 |
| cm | ms | g | daN | 105Pa | dam/s | Kg/l | dJ | 9.81e-4 |
| bar | ||||||||
| cm | ms | Kg | 104N | 108Pa | dam/s | K Kg/l | dJ | 9.81e-4 |
| (KdaN) | (Kbar) | |||||||
| cm | ms | Mg(ton) | 107N | 1011Pa | dam/sM | K Kg/l | 105J | 9.81e-4 |
| (MdaN) | (Mbar) | |||||||
| cm | s | g | 107N | 1011Pa | 104m/s | Kg/l | 105J | 9.81e-10 |
| (MdaN) | (Mbar) |
