The LS-DYNAユーティリティメニュー contains shortcuts and tools that can help simplify LS-DYNA tasks. Set the user profile from the User Profiles option of the Preferences menu.
The ユーティリティメニュー for the OptiStruct user profile contains, in addition to the default ユーティリティメニューs, three pages (Summary, FEA and Opti) of specific utilities for OptiStruct.
The Summary page of the OptiStructユーティリティメニュー lists a short summary using displayed or the entire model for components, loads, elements, center of gravity, moment
of inertia, responses and constraints.
Use the Export in MDL utility to export body and joint definitions in the current database to a Model Definition Language (.mdl) file that can be opened with MotionView.
Macros available on the FEA page of the OptiStructユーティリティメニュー.
I-DEAS to Radioss
The I-DEAS to Radioss converter utility converts an I-DEAS input file to an OptiStruct input file.
Export in MDL
Material Table
Use the Material Table utility to review and edit OptiStruct materials.
Component Table
The OptiStructComponent Table displays components and their associated attributes in an interactive table.
Property Table
The OptiStructProperty Table displays properties and their associated attributes in an interactive table.
Auto Contact
Use the Auto Contact tool to quickly and easily create one or more contact interfaces at once between several parts of your model.
Pretension Manager
Use the Pretension Manager tool to create and edit 1D and 3D pretension bolt loads and bolt sections for the OptiStruct solver.
Load Collector Table
Use the Load Collector Table utility to review and edit OptiStruct load collectors.
Buckling
The Buckling utility allows a buckling subcase to be defined simultaneously with its referenced static subcase.
