The LS-DYNAユーティリティメニュー contains shortcuts and tools that can help simplify LS-DYNA tasks. Set the user profile from the User Profiles option of the Preferences menu.
With this macro, you can create components, select components, assign materials to components, change component colors
and change component visualization modes.
Use the TABLE Create macro to create a tabular function card or add data to an existing card. You can use the macro
to import XY data or enter the data manually.
The ユーティリティメニュー for the OptiStruct user profile contains, in addition to the default ユーティリティメニューs, three pages (Summary, FEA and Opti) of specific utilities for OptiStruct.
Auto Contact
Create one or more contact interfaces between parts of your model.
Create a Spider
Use the RigidSpider macro to create a spider (RBE2 elements) around holes.
View Part Information
The PartInfo macro summarizes a part’s statistics in a dialog.
Component Table
With this macro, you can create components, select components, assign materials to components, change component colors and change component visualization modes.
Property Table
Use this macro to create properties, select properties, assign materials to properties and export the data in CSV or HTML format.
Material Table
The Materials Table is used to review and edit MAT1.
Create an RSSCON Element
The RSSCON Create macro creates an RSSCON element that connects the shell and solid.
Create an RSPLINE Element
The RSPLINE Create macro creates RSPLINE elements as Bulk unsupported cards.
Table Create
Use the TABLE Create macro to create a tabular function card or add data to an existing card. You can use the macro to import XY data or enter the data manually.
