View Bolt/Nut Tightening Forces
View simulation results for bolt/nut tightening loads.
Bolts tightening creates full 3D stresses. During animation, the bolts turn as specified in the input dialog. The deformation may be elongated at the ends, This is just due to the exaggerated deformation scaling and should not be considered unusual.
- In the Project Tree, expand the Results branch for your analysis.
Click Bolt/nut forces to open the Bolt/nut
forces dialog.
Figure 1. -
In the dialog or the modeling window, select a bolt or
nut.
The Force and moments are shown in the Legend.
Figure 2. -
Display additional columns with Force and Moment in the Bolt/nut
forces dialog.
- In the dialog, click on a column head.
- Select the additional columns to display.
- Drag the edges of the dialog to resize.
- Select any column head to sort the table.
Figure 3.
