Bearing Load
Apply sinusoidal varying pressure loads to faces of revolution.
  1. On the Project Tree, open the Analysis Workbench.
  2. Click on the desired Analysis branch.
  3. Next to Loads, click Add.
  4. Choose (Bearing load) from the list of loads.
    The Bearing load dialog opens.
  5. On the modeling window, click to select specific parts on the model.
    Remember: Bearing loads can only be applied to faces of revolution.
  6. Specify load type (radial, axial, or moment), value, and units.
  7. Use the slider or the gray arrows to define Load direction.
  8. Use the slider or the gray arrows to define Load span.
  9. Click OK.
    The load appears under the Load branch in the Project Tree. Vectors representing the load appear on the part in the modeling window.
