Gravity Load
Apply a uniformly distributed body load over the volumes of parts of an assembly.
- On the Project Tree, open the Analysis Workbench.
- Click on the desired Analysis branch.
Next to Loads, click
Add.
Choose
(Gravity load) from the list of loads.
The Gravity load dialog opens. - In the modeling window, select a part of the model.
- Specify load direction vectors for the X, Y, and Z axes.
- Specify the Amplification factor.
Click OK.
The load appears under the Load branch in the Project Tree. Vectors representing the load appear in the modeling window.
