Pressure Load
Apply positive pressure towards a face or negative pressure outwards from a face.
  1. In the Project Tree, open the Analysis Workbench.
  2. Click on the desired Analysis branch.
  3. Next to Constraints, click the (Add) button.
  4. Choose (Pressure) from the list of loads.
    The Pressure dialog opens.
  5. In the modeling window, select one or more faces.
  6. Optional: Select the Add tangent faces check box.
  7. In the dialog, specify the Pressure value and units.
  8. Click OK.
