/SURF/PROP/ALL
Block Format Keyword Describes the property surfaces which belong to given properties.
Enter selected items numbers (any number may be input, 10 per format).
/SURF/PROP/ALL/surf_ID/unit_ID
surf_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
surf_ID Surface identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
surf_title Surface title
item_ID1, item_ID2, ... item_IDn List of property identifiers
(Integer)
  1. The format is the same as the corresponding options /SURF/type/surf_ID.
  2. For solid elements, a surface segment is created for every face of a solid element that belongs to the item_ID listed.
    The segments built from 3-node and 4-node shells are still selected the same way as with /SURF/type/surf_ID.
