/SURF/PLANE
Block Format Keyword Describes an infinite PLANE surface defined by a normal vector MM1.
/SURF/PLANE/surf_ID/unit_ID
surf_title
XM YM ZM
XM1 YM1 ZM1
surf_ID Surface identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
surf_title Surface title
XM X coordinate of M (end of normal vector)
(Real)
YM Y coordinate of M (end of normal vector)
(Real)
ZM Z coordinate of M (end of normal vector)
(Real)
XM1 X coordinate of M1 (head of normal vector)
(Real)
YM1 Y coordinate of M1 (head of normal vector)
(Real)
ZM1 Z coordinate of M1 (head of normal vector)
(Real)
  1. The infinite PLANE is defined by a normal vector MM1 (M belongs to plane).
    surf_plane_normal_vector
