/SURF/ELLIPS
Block Format Keyword Describes the hyper-ellipsoid surface definition.
/SURF/ELLIPS/surf_ID/unit_ID | |||||||||
surf_title | |||||||||
skew_ID | n | ||||||||
Xc | Yc | Zc | |||||||
a | b | c |
surf_ID | Surface
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
surf_title | Surface
skew_ID | Skew identifier defining
the initial orientation of the surface (Integer) |
n | Degree of the
hyper-ellipsoid Default = 2 (Integer) |
Xc | Center
coordinate (Real) |
Yc | Center
coordinate (Real) |
Zc | Center
coordinate (Real) |
a | Semi-axis
length (Real) |
b | Semi-axis
length (Real) |
c | Semi-axis
length (Real) |
- All nodes must belong to a shell element, a brick element or a triangular shell element.
- A surface cannot be defined using Madymo surfaces.
- A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
- The equation of the
hyper-ellopsoid is:
(1) - A hyper-ellipsoid can only be a main surface of /INTER/TYPE14.
- Input format for MDELLIPS, see /SURF/MDELLIPS.
