/SURF/SEG
Block Format Keyword Describes the surface segments definition.
/SURF/SEG/surf_ID/unit_ID
surf_title
seg_ID1 node_ID1 node_ID2 node_ID3 node_ID4
seg_ID2 node_ID1 node_ID2 node_ID3 node_ID4
etc etc etc etc etc
seg_IDn node_ID1 node_ID2 node_ID3 node_ID4
Format for 2D and axisymmetrical analysis
etc etc etc
seg_IDn node_ID1
surf_ID Surface identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
surf_title Surface title
seg_ID1, seg_ID2, seg_IDn, Segment identifier (optional)
(Integer)
node_ID1 Node identifier 1
(Integer)
node_ID2 Node identifier 2
(Integer)
node_ID3 Node identifier 3
(Integer)
node_ID4 Node identifier 4 (optional for triangular elements)
(Integer)
  1. Surfaces are used to define interfaces in 3D analysis and pressure loads.
  2. The node_ID4 may be omitted for triangular elements.
  3. Segments may be given by "cut and paste" of shell element input data.
  4. All nodes must belong to a shell element, a brick element or a triangular shell element.
  5. A surface cannot be defined using Madymo surfaces.
  6. A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
