/SURF/GRSHEL
Block Format Keyword Describes the surface selected from shell groups.
Enter selected items numbers (any number may be input, 10 per format).
/SURF/GRSHEL/surf_ID/unit_ID
surf_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
surf_ID Surface identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
surf_title Surface title
item_ID1, item_ID2, ... item_IDn List of shell group identifiers
If item_ID is negative, the surface normals are inverted.
(Integer)
  1. All nodes must belong to a shell element, a brick element or a triangular shell element.
  2. A surface cannot be defined using Madymo surfaces.
  3. A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
