/SURF/SUBMODEL
Block Format Keyword Describes the submodel surfaces which belong to given submodels.
Enter selected items numbers (any number may be input, 10 per format).
/SURF/SUBMODEL/surf_ID/unit_ID
surf_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
surf_ID Surface identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
surf_title Surface title
item_ID1, item_ID2,... item_IDn List of submodel identifiers 4
(Integer)
  1. All surface segments must belong to 2D elements (shell element or a triangular shell element). 1D elements are ignored in /SURF/SUBMODEL. With 3D elements, an additional keyword must be specified: see /SURF/SUBMODEL/EXT and /SURF/SUBMODEL/ALL
  2. A surface cannot be defined using Madymo surfaces.
  3. A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
  4. If item_ID is negative, the surface normals are inverted.
