Ityp = 1
Block Format Keyword This law enables to model a liquid inlet condition by providing data from stagnation point. Liquid behavior is modeled with linear EOS. Input card is similar to /MAT/LAW11 (BOUND), but introduces two new lines to define turbulence parameters.
![law11_ityp0](../../../images/solvers/law11_ityp0.png)
/MAT/B-K-EPS/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
Ityp | Psh | FscaleT |
node_IDv | C1 | Cd | |||||||
fct_ID | |||||||||
fct_IDp | |||||||||
fct_IDE | |||||||||
fct_IDk | fct_ID | ||||||||
fct_IDT | fct_IDQ |
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
mat_title | Material
title. (Character, maximum 100 characters) |
Initial stagnation
density. 3 (Real) |
Reference density used in
E.O.S (equation of state). Default (Real) |
Ityp | Boundary condition type.
1
(Integer) |
Psh | Pressure shift. 2 (Real) |
FscaleT | Time scale factor. 3 (Real) |
C1node_IDv | Node identifier for velocity computation. 4
(Integer) |
C1 | Liquid bulk modulus. 9 (Real) |
Cd | Discharge coefficient.
5 Default = 0.0 (Real) |
fct_ID | Function
identifier for stagnation
density. 3
(Integer) |
fct_IDp | Function
pressure. 3
(Integer) |
Initial stagnation
pressure. 3 (Real) |
Initial specific volume
energy at stagnation point. 38 (Real) |
Initial turbulent
energy. (Real) |
Initial turbulent
dissipation. (Real) |
fct_IDk | Function
identifier for turbulence
modeling.
(Integer) |
fct_ID | Function
identifier for
(Integer) |
Turbulent viscosity
coefficient. Default = 0.09 (Real) |
Diffusion coefficient for
k parameter. Default = 1.00 (Real) |
parameter. Default = 1.30 (Real) |
Ratio between Laminar
Prandtl number (Default 0.7) and turbulent Prandtl number (Default
0.9). (Real) |
fct_IDT | Function
identifier for inlet temperature.
(Integer) |
fct_IDQ | Function
identifier for inlet heat flux.
(Integer) |
- Provided gas state from stagnation
point
is used to compute inlet gas state. Bernoulli is
then applied.
(1) This leads to inlet state:(2) (3) (4) - The Psh parameter enables shifting the output pressure, which also becomes P-Psh. If using , the output pressure will be , with an initial value of 0.0.
- If no function is defined, then related quantity and Q remains constant and set to its initial value. However, all input quantities and Q can be defined as time dependent function using provided function identifiers. Abscissa functions can also be scaled using FscaleT parameter which leads to use instead of .
- Inlet velocity is used in Bernoulli theory.
- Discharge coefficient accounts for
entry loss and depends on shape orifice.
Figure 2. - With thermal modeling, all thermal data ( , ...) can be defined with /HEAT/MAT.
- It is not possible to use this boundary material law with multi-material ALE /MAT/LAW37 (BIPHAS)) and /MAT/LAW51 (MULTIMAT).
- Definition of stagnation energy is
optional. Default value is recommended:
; since linear EOS
does not depends on energy pressure is not affected
and the initial energy is also set by you.
Specific volume energy E is defined as ,
Where- Internal energy. It can be output using /TH/BRIC.
Specific mass energy e is defined as . This leads to . Specific mass energy e can be output using /ANIM/ELEM/ENER. This may be a relative energy depending on user modeling.
- Liquid bulk modulus is usually set
to
.Where,
- Sound speed
