/MAT/B-K-EPS
Block Format Keyword This law describes the boundary conditions material in flow analysis (ALE or EULER). It is based on boundary material /MAT/LAW11 (BOUND) activating boundary turbulence modeling and adding 2 input lines for k - ε ˙ parameters. It is compatible for 2D and 3D analysis. It is not compatible with Multi-material ALE laws, LAW37 (BIMAT) and /MAT/LAW51 (MULTIMAT).
Formulation Types
Boundary Material Types
Formulation Type Comments
Ityp = 0 Gas Inlet State computed from given data at stagnation point
Ityp = 1 Liquid Inlet State computed from given data at stagnation point
Ityp = 2 General Inlet/Outlet State directly defined by user data
Ityp = 3 Non-Reflecting Boundary
