/MAT/LAW46 (LES_FLUID)
Block Format Keyword Describes the viscous fluid material with sub-grid scale viscosity.
/MAT/LAW46/mat_ID/unit_ID or /MAT/LES_FLUID/mat_ID/unit_ID
mat_title
ρ i ρ 0
c ν
Isgs Cs Csp
mat_ID Material identifier.
(Integer, maximum 10 digits)
mat_title Material title.
unit_ID Unit Identifier.
(Interger, maximum 10 digits)
ρ i Initial density.
(Real)
[ kg m 3 ]
ρ 0 Reference density used in E.O.S (equation of state).
Default ρ 0 = ρ i (Real)
[ kg m 3 ]
c Speed of sound.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
ν Molecular kinematic viscosity.
(Real)
[ m 2 s ]
Isgs Sub-grid scale model.
= 0
No sub-grid viscosity.
= 1 (Default)
Smagorinsky model.
= 2
Smagorinsky with acoustic damping.
= 3
Identical to Isgs =2 with modified Δ value.
(Integer)
Cs Smagorinsky constant.
Default = 0.1 (Real)
Csp Pressure damping coefficient.
Default = Cs (Real)
[ 1 s ]
#RADIOSS STARTER
/MAT/LAW46/5
FLUID (unit: kg_m_s)
#              RHO_I
              1562.5
#                  c                  NU
               593.3              2.4e-6
#     Isgs                 C_s                 Csp
         2                   0                   0
/EULER/MAT/5
#     Modif. factor.
                   0
#ENDDATA
/END
  1. For Isgs = 1 or 2, Δ = Volume 3 .
  2. For Isgs = 3, Δ is the smallest dimension of each element.
  3. ν sgs is computed as:(1)
    ν sgs = ( Cs Δ ) 2 ( e ij ) 1 2
  4. This law is modified near wall boundaries:
    ν + ν sgs = ν k y 2 + ln ( E y 2 + ) if y 2 + 11.225
    ν sgs = 0 , otherwise.
    Where,
    ν sgs
    Sub grid scale viscosity
    k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4Aaaaa@36E7@
    von Kahrman constant
