/HEAT/MAT
Block Format Keyword Describes thermal parameters for thermal analysis.
| /HEAT/MAT/mat_ID/unit_ID | |||||||||
| T0 | AS | BS | Iform | ||||||
| T1 | AL | BL | EFRAC | ||||||
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| T0 | Initial temperature (1st
part). Default = 300K (Real) |
| (Mandatory) Specific heat per unit
volume. (Real) |
| AS | Thermal conductivity coefficient A for
solid phase. (Real) |
| BS | Thermal conductivity coefficient B for
| Iform | Heat transfer formulation flag.
(Integer) |
| T1 | Temperature of melting point. Default = 1020 (Real) |
| AL | Thermal conductivity coefficient A for
liquid phase. (Real) |
| BL | Thermal conductivity coefficient B for
| EFRAC | Fraction of strain energy converted into
heat. Default = 1. (Real) |
Example (Thermal)
#RADIOSS STARTER
#- 1. MATERIALS:
/UNIT/1
unit for mat
Mg mm s
/MAT/PLAS_JOHNS/1/1
Steel
# RHO_I
7.8E-9 0
# E Nu
210000 .3
# a b n EPS_p_max SIG_max0
270 450 .6 0 0
# c EPS_DOT_0 ICC Fsmooth F_cut Chard
0 0 0 0 0 0
# m T_melt rhoC_p T_r
0 0 0 0
/HEAT/MAT/1/1
# T0 RHO0_CP AS BS IFORM
273 3.588 19.0 0 1
# Blank card
/THERM_STRESS/MAT/1/1
# func_IDT Fscale_y
1003 0
#- 2. FUNCTIONS:
/FUNCT/1003
linear expansion coefficient funtion of temperature
# X Y
273 1.2E-5
800 1.2E-5
#enddata
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----|Comments
- is a mandatory option; otherwise, Starter will error out.
- Values defined in this card overwrite the equivalent values defined in the material.
- This option is available for all material laws;
except the following:
LAW0, 5, 6, 11, 21, 26, 37, 41, 46, 51, 54, 97, 108, 113, 151, /MAT/B-K-EPS, /MAT/K-EPS, and /MAT/GAS
- This option is compatible with equations of state, /EOS, only when used with the following materials: LAW3, 4, 12, and 49
- This option is available for:
- All shell elements formulations; except DKT18 and T6
- All solid elements formulations; except PA6
- The
(thermal conductivity) is computed as:
(1) Where, is the current temperature in Kelvin.
- The α (thermal diffusivity) is computed as:
(2) Where, is the heat capacity at constant pressure.
- New
(3) - T1, AL, and BL can be used only for solid elements when finite volume method is used (Iform = 0).
- There is no thermal coupling between an ALE thermal material and a Lagrangian thermal material.
