PutTab()
Put a tab parameter in the data base.
Usage
PutTab( path, par,
                 value, clobber=True )
path (string)
Data base path of the node containing the parameter.
par (string)
Parameter name.
value (string)
The parameter value.
clobber (boolean)
The parameter value will be overwritten if clobber is true.
Return Value
None
Error
The parameter must be one of the defined tab names.
This routine saves a tab parameter in the data base. The parameter address is given by its node path and the par name. The value of parameter is given by value. If the clobber is true, the parameter value will be overwritten. For example,
nodeMat = ROOT + RS + 'MATERIAL_MODEL'
PutTab( nodeMat, 'tab','density',False)
