AcuSolve
AcuSolve
2021
  1. Home
  2. AcuConsole Customization Manual
    Customization of AcuConsole allowing you to improve your particular workflow.
  3. Data Tree Functions
  • What's New
  • Get Started
  • Tutorials
  • AcuSolve Training Manual
  • AcuSolve Validation Manual
  • AcuSolve Command Reference Manual
  • AcuSolve Programs Reference Manual
  • AcuSolve User-Defined Functions Manual
  • AcuConsole Mesh Generation Manual
  • AcuConsole Customization Manual
  • AcuTrace Command Reference Manual
  • AcuTrace User-Defined Functions Manual
  • AcuFieldView User Guide
  • AcuReport Reference Manual
  • AcuSolve Surface Processing
Index
AcuSolve
2021
AcuSolve
  • What's New
    View new features for AcuSolve 2021.
  • Get Started
    AcuSolve is a leading general purpose CFD solver that is capable of solving the most demanding industrial and scientific applications.
  • Tutorials
    Discover AcuSolve functionality with interactive tutorials.
    Introduction of background knowledge regarding flow physics and CFD as well as detailed information about the use of AcuSolve and what specific options do.
    Collection of AcuSolve simulation cases for which results are compared against analytical or experimental results to demonstrate the accuracy of AcuSolve results.
    AcuSolve command descriptions and corresponding examples.
    AcuSolve utility programs covering preparatory and post-processing as well as user-defined functions and utility scripts.
    Customization of AcuSolve allowing you to customize certain capabilities of the solver.
    Instruction of the mesh generation capability in AcuConsole, a GUI based pre-processor for AcuSolve.
    • General Structure
      AcuConsole has three main windows including the Data Tree, panel and the visualization window.
    • Main File
      Any number of custom user panels may be written. For each user panel, a tree item must be created. These are referred to as leave node tree items.
    • User Panels
      Each user panel must have an open function, containing the menu definitions, and a call to TreeItem(), to place an item on the Data Tree and hook it up to the panel function. In addition, it may contain any number of supporting functions and operations, including data initialization.
    • Standard Database Nodes
      The custom user panels may access and update any parameter in the database.
    • User Panel Example
      The following is an example of a simple user panel for simplifying a StaticMixer specification. For clarity, help arguments are omitted.
    • Set Command's Parameters (cmdSetXXX( ) )
      There are general functions written for each panel command to set the command's parameters to their default values and put the valid values in the database according to the defined path.
    • Database Access Functions
    • Registration Functions
    • Database Functions
    • Menu Functions
    • AcuSolve Input Functions
    • Data Tree Functions
      • ExportLib()
        Export a Data Tree item (and all its children) into a standalone library file.
      • ItemOpen()
        Open a tree item in the Data Tree.
      • TreeItem()
        Create a new tree item.
      • TreeRedraw()
        Redraw the Data Tree.
    • Grouping Functions
    • Vis Window Functions
    • Miscellaneous Functions
    • Tools
    • Process Automation
    • AcuDialog
      AcuDialog is a Python module that provides a dialog with different types of menus on it.
    • AcuDialog Menu Functions
    Commands of AcuTrace, a particle tracer that runs as a post-processor to or a co-processor with AcuSolve.
    Instructions to define additional solution quantities of AcuTrace called user equations.
    Usage of AcuFieldView, an OEM version of Intelligent Light’s FieldView post-processing software.
    Instruction of the AcuReport tool, a standalone post-processor batch tool used to generate a report from an AcuSolve solution database.
AcuSolve
AcuSolve
2021
  1. Home
  • What's New
  • Get Started
  • Tutorials
Index
Data Tree Functions
  • ExportLib()
  • ItemOpen()
  • TreeItem()
  • TreeRedraw()
