User Panel Example
The following is an example of a simple user panel for simplifying a StaticMixer specification. For clarity, help arguments are omitted.
# Define the grouping tab #===========================================================================
def usrTabStaticMixerGroup( item, args ):
node = ROOT + RS + 'User' + RS + 'Mixing' + RS + 'StaticMixer'
# Define the physics tab #===========================================================================
def usrTabStaticMixerPhysics( item, args ):
# Define the Bcs tab #===========================================================================
def usrTabStaticMixerBcs( item, args ):
# Define the open function #===========================================================================
def usrOpenStaticMixer( item, args ):
MenuTab( tabs = ( ( 'Group', 'group' ), ( 'Physics', 'physics' ),
( 'BCs', 'Bcs' )),
node = node,
par = 'tab',
redraw = True,
default = 'group' )
tab = GetTab( node, 'tab' )
if tab == 'group':
if tab == 'physics':
if tab == 'Bcs':
# Add to the tree item #=========================================================================== TreeItem( parent = UsrMixing,
name = 'Static Mixer',
tooltip = 'Simplified Static Mixer Panels',
whatsthis= 'Open the custom panels to<br>' 'specify a static mixer',
helpURL = 'static_mixer.html',
popup = (( 'Open', usrOpenStaticMixer ),),
click2 = 'Open' )
# Initialize the data base values (if not already in the data base) #=========================================================================== node = ROOT + RS + 'User' + RS + 'Mixing' + RS + 'StaticMixer'
PutTab( node, 'tab', 'group', False )
