AcuFieldView User Guide
Usage of AcuFieldView, an OEM version of Intelligent Light’s FieldView post-processing software.
AcuFieldView is packaged and shipped exclusively with AcuSolve. AcuFieldView is a dedicated CFD post-processor that is designed only for use with results that were generated by AcuSolve. AcuFieldView can be launched from within AcuConsole, or launched as a separate application from a Start menu shortcut or via the command line.
Contains material licensed from Intelligent Light (www.ilight.com) and used by permission.
