Quick Pick
Use the Quick Pick feature to quickly navigate through surface and rake panels.
To navigate to a surface or rake in your display, you can open a Visualization panel from either the side toolbar or the Visualization pull-down menu. However, a much easier way to raise the Visualization panel for any surface or rake is simply to double-click it. This technique is called quick pick and applies to all surfaces and rakes in AcuFieldView. This lets you quickly navigate through surface and rake panels. Quick pick can be used across datasets and can be used in Keyframe Animation.
Quick picking on the boundary surface by double-clicking automatically opens the Boundary Surface panel.
