Memory Requirements
The actual swap (or paging) space needed to process your data generally depends on the size of the dataset.
It will also depend on the probe performance settings. In general, the greater the FV_PROBE_PERFORMANCE variable, the greater the memory requirements [in MB] for AcuFieldView.
- All other structured grid datasets
- 1400 + 1.4 x 10-4 x number of nodes
- FV-UNS native binary/unformatted
- 1400 + 1.3 x 10-4 x number of elements
- All other unstructured
- 1400 + 2.1 x 10-4 x number of elements
- 1400 + 4.0 x 10-5 x number of nodes
- 1400 + 0.9 x 10-5 x number of elements
- 1400 + 9.0 x 10-5 x number of elements
These formulas are approximations. Memory requirements will depend on the structure of your dataset, especially for larger values of FV_PROBE_PERFORMANCE. For best performance, the amount of random access memory (RAM) available should be equal to at least half of the memory requirements shown above.
