Start AcuFieldView
Following a successful installation, Linux users will run AcuFieldView by typing acuFv in a
console window. You will need to ensure that you are either in the directory
FV_HOME/bin
or that you have added this directory to your path.
If you have not done this, you will need to type the full path name where AcuFieldView is installed.
Windows users will click AcuFieldView from a Windows command prompt, or a Cygwin shell, type acuFv.bat followed by any desired command line arguments.
. To run
