PutFile()
Put a file parameter in the data base.
Usage
PutFile( path, par,
value, clobber=True )Parameters
- path (string)
- Data base path of the node containing the parameter.
- par (string)
- Parameter name.
- value (string (path of File)
- The parameter value.
- clobber (boolean)
- The parameter value will be overwritten if clobber is true.
Return Value
None
Error
The parameter must be a string.
nodeFile = Root + RS + 'file'
PutFile( nodeFile, 'filevalue', 'F:\Acusim\Readme.txt', False )
