PutReal()
Put a real parameter in the data base.
Usage
PutReal( path, par,
value, clobber=True,
**opts )
- path (string)
- Data base path of the node containing the parameter.
- par (string)
- Parameter name.
- value (real)
- The parameter value.
- clobber (boolean)
- The parameter value will be overwritten if clobber is true.
- **opts (list)
- List of options.
Return Value
None
Error
The parameter must be a real.
nodeStg = nodeStg + RS + name
PutReal( nodeStg, 'velocity_projection_tolerance',0.1,False)
