GetParModId()
Get the modified ID of a parameter from the data base.
Usage
mId = GetParModId( path, par )
path (string)
Data base path of the node containing the parameter.
par (string)
Parameter name.
Return Value
mId (integer)
The modified ID of the parameter.
  • The parameter in the data base must be of a valid type.
  • The parameter must exist in the data base.
This routine returns the modified ID of a parameter from the data base. The parameter address is given by its node path and the par name. A parameter with higher mId has been updated (modified) more recently than one with lower mId. For example,
modId = GetParModId( ROOT + RS + 'main', 'auto_ss' )
