PutStr()
Put a string parameter in the data base.
Usage
PutStr( path, par,
value, clobber=True )
- path (string)
- Data base path of the node containing the parameter.
- par (string)
- Parameter name.
- value (string)
- The parameter value.
- clobber (boolean)
- The parameter value will be overwritten if clobber is true.
Return Value
None
The parameter must be a string.
nodeStg = ROOT + RS + 'STAGGER'
PutStr( nodeStg, 'staggers', 'type', False )
