GetList()
Get a list parameter from the data base.
Usage
listPar = GetList( path, par, default=None )
- path (string)
- Data base path of the node containing the parameter.
- par (string)
- Parameter name.
- default
- Default value. This value is returned if the indicated path and par does not exist.
Return Value
- listPar (list)
- The parameter value.
- The parameter in the data base must be a list.
- The parameter must exist in the data base or the default must not be None.
nodeEms = ROOT + RS + 'EMISSIVITY_MODEL' + item.name
userStr = GetList( nodeSun, 'user_strings' )
