PutDic()
Put a dictionary parameter in the data base.
Usage
PutDic( path, par,
value, clobber=True )
- path (string)
- Data base path of the node containing the parameter.
- par (string)
- Parameter name.
- value (dictionary)
- The parameter value.
- clobber (boolean)
- The parameter value will be overwritten if clobber is true.
Return Value
None
Error
The parameter must be a dictionary.
nodeDb = ROOT + RS + 'main'
nodeCad = nodeDb + RS + 'CAD_DATA'
PutDic( nodeCad,'sibFaceMap', sibMap )
