GetUnit()
Get a unit option for a parameter from the data base.
Usage
unit = GetUnit( path, name )
- path (string)
- Data base path of the node containing the parameter.
- name (string)
- Parameter name.
Return Value
- unit (string)
- The unit parameter.
Error
The parameter must exist in the data base.
This routine returns the unit option for a parameter from the data base. The parameter address is given by its node path and the name.
