getRef()
Get a ref par value from database.
Usage
refVal = acs.getRef( par, path )
par (string)
The parameter name.
path (string)
Data base path of the par.
Return Value
refVal (string)
The parameter value.
The path should be valid.
The parameter in the data base must be a String.
This routine returns a ref parameter from the data base. The parameter address is given by its node path and the par name. For example,
nodeElm = ROOT + RS +'Model'+ RS +'Volumes'+ RS +'impeller' + RS + 'ELEMENT_SET'
matName = acs.getRef( 'material_model', nodeElm )
