Run Time Options for AcuReport
Each program requires zero or more command-line options to run.
The supported command-line options for AcuReport are:
-h
Print usage and exit. It is equivalent to help = TRUE [command-line]
  • Default value
    The default value of this option is False.
  • Example
    acuReport -h
-file<str>
File name of the report generation script ; (_auto, uses <problem>.rep)
  • Default value
    The default value of this option is "_auto".
  • Example
    acuReport -file pump.rep
-pb<str>
Problem name
  • Default value
    The default value of this option is "_undefined".
  • Example
    acuReport -pb pump
-dir<str>
Working directory which includes all the intermediate and final data generated by ACUSIM modules.
  • Default value
    The default value of this option is "ACUSIM.DIR".
  • Example
    acuReport -file pump.rep -dir pump
    Note: In the above example, pump directory must exist and includes the data generated by ACUSIM modules.
-run<int>
Run number
  • Default value
    The default value of this option is 0.
  • Example
    acuReport -file pump.rep -run 1
-acs<str>
AcuConsole database name; (_auto, uses <problem>.acs)
  • Default value
    The default value of this option is "_auto ".
  • Example
    acuReport -file pump.rep -acs pump.acs
-pdf
Create PDF file.
  • Default value
  • Example
    acuReport -file pump.rep -pdf
-rtf
Create .rtf file
  • Default value
  • Example
    acuReport -file pump.rep -rtf
-HTML
Create HTML file
  • Default value
  • Example
    acuReport -file pump.rep -html
-usr1<str>
User specific option 1, accessible in the report
  • Default value
    The default value of this option is "None".
  • Example
    acuReport -file pump.rep -usr1 case1
-usr2<str>
User specific option 2, accessible in the report
  • Default value
  • Example
    acuReport -file pump.rep -usr2 case2
-v<int>
Verbose level
  • Default value
  • Example
    acuReport -file pump.rep -v 1
