getFile()
Get a file par value from database.
Usage
fileVal = acs.getFile( par, path )
par (string)
The parameter name.
path (string)
Data base path of the par.
Return Value
fielVal (string file path)
The parameter value.
The path should be valid.
The parameter in the data base must be a String value.
This routine returns a file parameter from the data base. The parameter address is given by its node path and the par name. For example,
nodeEqn = ROOT + RS + 'EQUATION'
inpFile = acs.getFile( par = 'inp_file', path = nodeEqn
