getEnum()
Get an enum par value from database.
Usage
enumVal = acs.getEnum( par, path )
par (string)
The parameter name.
path (string)
Data base path of the par.
Return Value
enumVal (enumerated)
The parameter value.
The path should be valid.
The parameter in the data base must be an Enum value.
This routine returns an enum parameter from the data base. The parameter address is given by its node path and the par name. For example,
modelSrf = ROOT + RS + "Model" + RS + "Surfaces"
nodeCbc = modelSrf + RS + name + RS + 'SIMPLE_BOUNDARY_CONDITION'
type = acs.getEnum( "type", nodeCbc )
