getFont ()
Get a font par value from database.
Usage
fontVal = acs.getFont( par, path )
par (string)
The parameter name.
path (string)
Data base path of the par.
Return Value
fontVal (string font size and name)
The parameter value.
The path should be valid.
The parameter in the data base must be a Boolean value.
This routine returns a font parameter from the data base. The parameter address is given by its node path and the par name. For example,
nodeEqn = ROOT + RS + 'EQUATION'
font = acs.getFont( par = 'font', path = nodeEqn )
