getList()
Get a list par value from database.
Usage
listVal = acs.getList( par, path )
- par (string)
- The parameter name.
- path (string)
- Data base path of the par.
Return Value
- listVal (list)
- The parameter value.
The path should be valid.
The parameter in the data base must be a List.
nodeMdl = ROOT + RS + 'Model'
meshSets = acs.getList( path = nodeMdl, par = 'meshSets' )
