getInt()
Get an integer par value from database.
Usage
intVal = acs.getInt( par, path )
- par (string)
- The parameter name.
- path (string)
- Data base path of the par.
Return Value
- intVal (integer)
- The parameter value.
The path should be valid.
The parameter in the data base must be an Integer value.
nodeEqn = ROOT + RS + 'EQUATION'
nSpecs = acs.getInt( path = nodeEqn, par = 'num_species' )
