getPasswd()
Get a password par value from database.
Usage
passwdVal = acs.getPasswd( par, path )
- par (string)
- The parameter name.
- path (string)
- Data base path of the par.
Return Value
- passwdVal (string)
- The parameter value.
The path should be valid.
The parameter in the data base must be a String.
nodeMdl = ROOT + RS + 'Model'
password = acs.getPasswd( path = nodeMdl, par = 'password' )
