getDic()
Get a dictionary par value from database.
Usage
dicVal = acs.getDic( par, path )
- par (string)
- The parameter name.
- path (string)
- Data base path of the par.
Return Value
- dicVal (dictionary)
- The parameter value.
The path should be valid.
The parameter in the data base must be a Dictionary.
nodeCad = ROOT + RS + 'main' + RS + 'CAD_DATA'
oldGeomModel = getDic( par = 'regGeomModel', path = nodeCad )
