getArray()
Get an array par value from the database.
Usage
aryVal = acs.getArray( par, path )
- par (string)
- The parameter name.
- path (string)
- Data base path of the par.
Return Value
- aryVal (array)
- The parameter value.
The path should be valid.
The parameter in the data base must be an Array.
nodeElm = ROOT + RS +'Model'+ RS +'Volumes'+ RS +'impeller' + RS + 'ELEMENT_SET'
rffName = acs.getRef( 'reference_frame', nodeElm )
nodeRff = ROOT + RS + 'REFERENCE_FRAME' + RS + rffName
rot = acs.getArray( 'angular_velocity', nodeRff )
